Re: M starting problem
Posted by John T on September 27, 2009 at 08:09:58 from (66.244.97.31):
In Reply to: M starting problem posted by weirdbeard on September 27, 2009 at 07:26:54:
I agree with Tom, the very FIRST thing I would do is remove, clean n wire brush, then re atatch EACH AND EVERY battery n starter n starter switch n ground cable connection and it dont hurt if the ground is to a good clean shiny bolt near the starter........ For 6 volt systems ESPECIALLY AN M I recommend 00 gauge battery n starter n ground cables plus the biggest heaviest highest CCA rated batttery that will physically fit and make sure its well charged. I also recommend not to hold the starter engaged a long period but try to milk the pistons up over on compression because a well tuned M should start when a piston comes up on compression TDC. If shes start timed too fast that can be hard on starting also.
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
