Re: Running and moving H with no tranny fluid
Posted by TomH in PA on September 27, 2009 at 09:50:47 from (67.234.26.50):
In Reply to: Running and moving H with no tranny fluid posted by Mike CA on September 27, 2009 at 09:39:25:
With the clutch in, nothing will be moving back there. Jam the pedal down with a block or something.
I'd just push it in and out of the garage. But a couple of gallons of gear lube won't be enough to reach the old seal and leak out.
This post was edited by TomH in PA at 09:55:01 09/27/09 2 times.
