Oil to Use With M&W Live Hydraulic Pump
Posted by keithg on September 27, 2009 at 10:53:16 from (173.28.129.191):
Been reading and learning a lot from this forum recently, but this is my first post.
I have been working on a 47 M which has an M & W engine driven live hydraulic pump in place of the belly pump. It also has an IH remote hydraulic valve mounted next to the belt pulley housing.
Original owner had been using 20W-20 non detergent motor oil in later years, but have not seen that grade of oil in stores. I understand M & W pump instructions from the 50's recommended "Sinclair Gascon Heavy Duty Hydraulic Oil or equivalent" whatever that was.
What oil would you recommend for use with this hydraulic system?
Tractor will see limited light duty without much opportunity to mix oil from other tractors & implements.
