Re: Int 460 Utility Whining noise and overheated hydraulics
Posted by Janicholson on September 27, 2009 at 13:15:44 from (64.61.211.43):
In Reply to: Int 460 Utility Whining noise and overheated hydraulics posted by Gunther on September 26, 2009 at 19:50:16:
The best info I have is to assure all control valves are returning to neutral. The hydraulics are open centered in that position. The filter can cause restriction causing cavitation and pump damage. Cleaning often loosens grime and the filter needs to be changed once after the original. Some filter systems (NAPA) and others are different, and might flow more, check that option. There should be a latch on the PTO lever that locks it into gear. Check the linkage to determine if it is operational. Do not use it slipping, it is a very expensive error. Good luck, JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
