Janicholson said: (quoted from post at 16:15:44 09/27/09) The best info I have is to assure all control valves are returning to neutral. The hydraulics are open centered in that position. The filter can cause restriction causing cavitation and pump damage. Cleaning often loosens grime and the filter needs to be changed once after the original. Some filter systems (NAPA) and others are different, and might flow more, check that option. There should be a latch on the PTO lever that locks it into gear. Check the linkage to determine if it is operational. Do not use it slipping, it is a very expensive error. Good luck, JimN
The hydraulic valves on the 460 are NOT open center. The system is a closed center system with an unloader valve to dump the oil back to reservoir when there is no demand from the valves.
The orifice/screen assembly in the control block allows oil to flow through and open the unloader valve. When any of the hydraulic valves are moved the oil flowing through the orifice is dumped and allows the unloader valve to close. That allow the system to go on high pressure.
The standby pressure on the system should be about 60 PSI. If the orifice becomes plugged or there is too much leakage through the valves the system will stay on high pressure.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
