If you go hydraulic, don't use a flow control valve. Just make sure that you size the pump and motor for the RPM you need or is recommended by the shredder mfg.
In the first picture, the extension can be made to any length. I don't think it extends past the tires but is probably close. A 45 HP high pressure water pump bolts to an adjustable base that in turn is bolted to the red eztension pad. Max speed of the pump is double 540 rpm.
The second picture is my 650. The air compressor is a Detroit Diesel air brake compressor. I use it to control a hydraulic gypsy head winch via a foot pedal. The winch elevates a 900 lb drop hammer.
Your easiest and cheapest solution is to mount the shredder as if it were a front mounted cord wood saw (buzz saw). Run it with the belt pulley.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
