Re: Mounted plows for my H
Posted by BEC on September 27, 2009 at 20:03:37 from (205.188.116.73):
In Reply to: Mounted plows for my H posted by Stumpy on September 27, 2009 at 13:47:17:
You are looking for the H-86 two-way tractor plow for Farmall H with Lift-All attachment. The H-86
two-way plow is built for use with Farmall H.These are quick-attachable plows which can be put on the tractor in 5 min or taken off in less time.You will have to take off the draw bar first. The beams are long and attached well under the tractor. The depth is controlled by guage wheels through a locator lever. Each bottom is suspended from the rock-shaft arms by parallel links which stabilize the plow. Slotted bars between the links permit the bottoms sufficient lateral motion so they cannot interfere with easy steering.-----The M-188 differs from the H-86 because it is much heavier.It has a higher clearance under the beams.It has extra high landsides with wide , adjustable heel castings. Either of these plows can be equiped with 14,16 or 18 inch bottoms. Two 2 1/2 cylinders are required. One for each side of tractor. Hope this helps you identfy the plows you are looking at. I don"t know if the M-188 will work on the H or not. BEC
