Re: Farmall H bearing replacement
Posted by pete 23 on September 27, 2009 at 21:00:17 from (173.87.8.73):
In Reply to: Farmall H bearing replacement posted by Russ Moore on September 27, 2009 at 13:42:20:
You can replace the rear main also, requires removing the plate that oil pan seals on, may tear gasket on rear oil seal retainer but a good silicone sealer will take care of it. Can't replace the rear seal though without removing flywheel.
