Posted by Bob M on September 28, 2009 at 05:08:51 from (151.190.254.108):
In Reply to: super m knock posted by jdetig1 on September 27, 2009 at 19:11:03:
If the knock disappears when the steering pump belt is removed look for loose crankshaft pulley(s). (You certain the big 2-1/2" nut that holds the pulley is tight?)
Another possiblity is the camshaft gear hub has cracked. This is a common failure on live pump-equipped Super M tractors. Test by lifting an implement with hydraulics with the engine idling. If the knock changes or disappears when the pump's loaded it means the cam gear is going away.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
