Posted by Janicholson on September 28, 2009 at 06:36:46 from (199.17.6.222):
In Reply to: super m knock posted by jdetig1 on September 27, 2009 at 19:11:03:
AS noted below bearing caps are not interchangable. you probably have more than .005" clearance on #1 main. When pulling up on it with the belt, it opens the clearance. when it fires, it slaps the clearance into the cap. (my guess) To check it, make sure the pulley is tight, then use a dial indicator on the pulley flange, positioned so it is vertical. Use a pry bar to push down on the pully flange. set the dial to zero, then push up on the flange and read the indicator. At that distance from the bearing it should not be more than .005". (this probably translates to about .003 at the bearing) if it is more, do not run it till it is fixed. As stated, line boring is necessary (with the cap fit to allow metal to be removed (shaved cap mating surfaces) Best of luck, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
