Re: 100 still hasn't started
Posted by El Toro on September 28, 2009 at 09:22:30 from (74.103.74.58):
In Reply to: 100 still hasn't started posted by couv on September 28, 2009 at 05:11:04:
Have checked to see if you have battery voltage
to the coil? With the points open and the ignition switch on you should have battery voltage on both terminals on the coil. Use a volt meter or a test lite. If there's no voltage present you need to check back at the ignition switch for voltage. Should have a wire feeding the switch battery voltage. If there's no voltage to the switch you need to trace the feed wire to see if its broken. You can run a separate wire from the battery to your coil and see if it will start. This will bypass your ignition switch. Hal
