Last night and tonight I revisited the generator. With the armature in, it showed a short from the field post to the case. With the armature removed, it showed an open from the field post to the case (?!) Obviously, the armature had something to do with what was going on.
I noticed that the screw holding the terminal for the brush wire to the armature post was a little loose. Lo and behold, the same loose screw had allowed the wire from the armature post to the field coil to move around enough to contact the commutator, which had worn j...u...s...t enough insulation off the wire to create a field-to-commutator short.
So I snipped off the field wire's terminal, replaced the old insulation with some 1mm i.d. heat shrink tubing, soldered on a new terminal, and carefully rerouted the wire about 1/8” from the case and far from the commutator.
Now the field reads 5.5 Ohms. The generator motors fine, and speeds up when the field isn't grounded – just like it should!
Next (after payday) will be a new U.S.-made regulator of the correct polarity, a complete check of all the wiring, and likely a new ammeter.
I just want to say thanks a ton for your help and explanations. It's also good to know this issue will hang out in the archives just in case the same problem bites someone else in the future.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
