Re: Manifold torque on bolts ? for A
Posted by Jeff Z. on September 28, 2009 at 19:02:41 from (74.76.3.113):
In Reply to: Manifold torque on bolts ? for A posted by tackhammertime on September 28, 2009 at 17:41:32:
Start in the middle and work both sides together towards the ends. When you do this just snug them. Then go back and in the same order from center to ends and torque them to spec.
