Re: Farmall 504 Injector Pictures: Re Engine Knock
Posted by rustred on September 29, 2009 at 07:59:14 from (209.115.232.65):
In Reply to: Farmall 504 Injector Pictures: Re Engine Knock posted by charles todd on September 28, 2009 at 20:03:32:
most certainly is the culprit.i take it your getting them all checked out.could be others on border line.those precups only go in one way , and are marked "up" on them. they are in the proper position now,#4 looks a little sideways. otherwise it will be hard starting.should renew those ring gskts.and clean everything good.those are a neat little engine, as i have one in a 340 utility.
