Re: OT 671 Detroit Clutch Problem
Posted by Janicholson on September 29, 2009 at 09:14:14 from (199.17.6.222):
In Reply to: OT 671 Detroit Clutch Problem posted by John T on September 28, 2009 at 13:37:52:
John I Have it.
There is lost motion in the cluch pedal linkage that is taking up the majority of the travel. The pivot for the pedal, or the bracket it mounts to, ot the rod linkage/bellcrank system, or the fork pivot is worn/loose/broken and flexing. The T/O bearing should move 3/4" or more after touching the fingers. You will find it outside of the work already done. Jim
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
