Posted by Janicholson on September 29, 2009 at 09:23:14 from (199.17.6.222):
In Reply to: 460 farmall conversion posted by MOOSEFARMER on September 29, 2009 at 07:26:07:
An alternator will be fine. Delco 10SI is a good model. Use the system shown, and all is well. Diode, light, or resistor in the circuit to the ignition key for exciting voltage will work. If it is already 12v, no changes to the ignition should be needed. Swap the polarity of the ignition coil to negative to the distributor, and swap all terminals on the amp meter to make it read correctly. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
