Re: 460 farmall conversion
Posted by Owen Aaland on September 29, 2009 at 11:54:17 from (207.13.114.55):
In Reply to: 460 farmall conversion posted by JS3 on September 29, 2009 at 07:26:07:
Janicholson said: (quoted from post at 12:23:14 09/29/09) An alternator will be fine. Delco 10SI is a good model. Use the system shown, and all is well. Diode, light, or resistor in the circuit to the ignition key for exciting voltage will work.
If it is already 12v, no changes to the ignition should be needed. Swap the polarity of the ignition coil to negative to the distributor, and swap all terminals on the amp meter to make it read correctly. JimN
bob M believable diagrams
The 460 came negative ground from the factory. There should be no need to reverse the leads at the coil and amp meter.
