Re: 79 INT cub
Posted by Bigdog on September 29, 2009 at 12:52:32 from (71.64.18.18):
In Reply to: 79 INT cub posted by Farmall Boyz on September 28, 2009 at 19:32:10:
The grilles are different. The 64 - 74 is a white expanded metal and the 75 and up are black and I believe the shell is slightly different in shape.
If it is an international cub it will be yellow and white. There were a few red Farmall cubs produced during that time frame but not many.
Here is a 64:
http://photos.cubfest.com/albums/userpics/10864/P9210011_edited-4.jpg
And a 79 Farmall:
http://photos.cubfest.com/albums/userpics/10054/PICT0102small.JPG
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
