Re: Ignition problem
Posted by Shawn in Pa on September 29, 2009 at 16:12:11 from (72.23.162.33):
In Reply to: Ignition problem posted by Terry Gowen on September 28, 2009 at 19:38:58:
The coil should say something like "12 volt use without external resistor". Or "use with external resistor". Get a coil that is internally ballasted and eliminate the external resistor. I agree and would lean toward the coil being cooked.
