Re: Tire Size for 13 Inch Rims - IH 300 U
Posted by Hugh MacKay on September 30, 2009 at 02:27:02 from (216.208.58.157):
In Reply to: Tire Size for 13 Inch Rims - IH 300 U posted by NewYorkTom on September 29, 2009 at 16:36:02:
Tom: Every farm tractor tire on the market has stamped on it, the ideal rim size to be used. If you want top performance that is size to use. If your satisfied with less than ideal performance, a size larger or smaller will serve you quite well. It will devalue your tractor.
