Posted by gene bender on September 30, 2009 at 03:32:47 from (67.55.226.179):
In Reply to: 1949 Farmall C RPM range posted by Raymond in co on September 29, 2009 at 18:41:49:
Turn the idle adjustment screw on the throttle shaft some to see if that helps. Your input shaft on your gov housing is also probabky worn and has some wobble. The linkage also needs to be set properly. Lots of things can be wrong remember its over 50yrs young and you will never know who has in the past played with one part or another. The carb must be ok or it wouldnt start and run that would be the last thing to tear apart, First i would set the screw on the throttle shaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
