Re: Tire Size for 13 Inch Rims - IH 300 U
Posted by dhermesc on September 30, 2009 at 05:38:15 from (24.248.193.103):
In Reply to: Tire Size for 13 Inch Rims - IH 300 U posted by NewYorkTom on September 29, 2009 at 16:36:02:
If you really have 13" rims you'll find that 12.4" tires are too small (they may mount but they won't be anything you want to use). If 14.9 tires look overly large I doubt you have 13" rims - most likely 12" rims - especially on a 300 utility.
