Re: Water pump and tire pressure
Posted by Janicholson on September 30, 2009 at 07:50:52 from (199.17.6.222):
In Reply to: Water pump and tire pressure posted by HENRY E NC on September 29, 2009 at 20:48:19:
2 strokes on the pump zerks is good as stated below.
I would equalize the pressure to Old's 12psi, then put masking tape on 4 tread bars covering the whole contact surface. (2 on each tire on adjacent tread bars one outer and one inner)
Then i would drive it for a quarter mile at parade speeds, on pavement. Looking at the tape then indicates if too much pressure is in them (tape worn on middle of tire only), or too little (tape worn in spots on the outside, or irregularly). Adjust pressure accordingly. JimN
