Re: 12 Volt re-wire update (1941 M)
Posted by Theman on September 30, 2009 at 08:56:35 from (63.107.135.35):
In Reply to: 12 Volt re-wire update (1941 M) posted by WI Dave on September 30, 2009 at 07:52:32:
Dave,
When you get back to it, make sure the 'hot' wire through the alternator to the ignition switch is on the battery side of the starter button.
