Re: 12 Volt re-wire update (1941 M)
Posted by Janicholson on September 30, 2009 at 09:04:33 from (199.17.6.222):
In Reply to: 12 Volt re-wire update (1941 M) posted by WI Dave on September 30, 2009 at 07:52:32:
There must be a wire from the battery positive to the amp meter (usually from the bat wire post on the starter0 there must be no connection to the ignition at all if it is a magneto ignition. It is grounded through the switch to stop.
There must be a wire from the losd side of the amp meter to the light switch, and a wire from the load side to the ignition sw (if and only if it has a distributor ignition with seperate coil. JimN
