Re: 12 Volt re-wire update (1941 M)
Posted by Shawn in Pa on September 30, 2009 at 09:40:42 from (72.23.162.33):
In Reply to: 12 Volt re-wire update (1941 M) posted by WI Dave on September 30, 2009 at 07:52:32:
Your drawing looks like you have a distributor and coil rather than a mag. I agree with Jim. You want your hot wire through the load side of the ammeter. You should really only have 1 wire coming into the ammeter, the one coming from your alternator. All other wires hooked to the ammeter should be exiting from the other post. You"ll know if you hook them up backwards, because the ammeter will show discharge when it actually is charging. Just reverse the wires in that case. If you do have a distributor, you could always run a jumper wire directly from the battery to the coil just so you can hear it run. I realize that may not cure your problem, but it allows you to eliminate other components, such as coil, points, ect...
