Re: Water pump and tire pressure
Posted by MHMalcolm on September 30, 2009 at 13:20:40 from (66.66.148.252):
In Reply to: Water pump and tire pressure posted by HENRY E NC on September 29, 2009 at 20:48:19:
12-15 PSI in rear tires is good. My dad always said if you don"t have a gauge, inflate the tires until the edge of one of the lugs just comes up off the ground. That is the method I used when I was a kid, and when I started using a gauge, I found that method usually got you right around the 12-15 PSI range.
