Re: Water pump and tire pressure
Posted by Owen Aaland on September 30, 2009 at 13:24:09 from (207.13.114.55):
In Reply to: Water pump and tire pressure posted by HENRY E NC on September 29, 2009 at 20:48:19:
Over greasing the bearings should not cause seal damage. The lip of the front seal should be installed so that it faces forwards to seal out any debris that may be blown in from the fan. The rear seal faces forwards also so if you over grease it the grease will be forced out the front seal with no damage, just a mess.
The other zerk greases the impeller shaft and bushing. Since the front of the bushing is sealed with the packing, over greasing that one will force grease into the cooling system. Only grease that one enough until the pressure builds up, often less than a full stroke.
