Re: battery charging 2 6 volts wired in series
Posted by Hugh MacKay on October 01, 2009 at 03:31:35 from (216.208.58.108):
In Reply to: battery charging 2 6 volts wired in series posted by dmiller on September 30, 2009 at 21:21:05:
dmiller: You wouldn't have messed anything up, you can either charge them as two 6 volt batteries or as one 12 volt in series. Charging as two 6 volt may have told you something that you couldn't learn had you charged it in series. Did one battery require a lot more charging than the other? You could have a defective battery, (the one that took substancially more charge) and it will eventually take the good battery down. If you caught it in time, you might stress test the poorer battery, if bad enough, replace it.
There is also the argument on two battery systems, that one should always replace both at same time. I will say this, I've had good results changing one battery in a two-six, series system, however not in a two-twelve parallel system.
If you found they took roughly same charging, you may as well keep using them as long as you can tolerate them.
