Re: who can check a 6 v coil ?
Posted by Hugh MacKay on October 01, 2009 at 03:42:47 from (216.208.58.108):
In Reply to: who can check a 6 v coil ? posted by couv on September 30, 2009 at 19:31:23:
couv: Why don't you just do something the guys recommend. You have spark, or it wouldn't backfire. Your timing advance is off substancially. The guys told you what to do in a previous thread. Why not just do as they told you?
My experience, if a 4 cylinder gas Farmall has spark at the right time, and has gas coming to the cylinders, it will go. Maybe not very well but it will start and run well enough for fine tuning.
By the way, best check going for a coil, doesn't matter whether 6 or 12, is 1 hour running.
