Re: who can check a 6 v coil ?
Posted by John T on October 01, 2009 at 05:02:42 from (66.244.97.31):
In Reply to: who can check a 6 v coil ? posted by couv on September 30, 2009 at 19:31:23:
YOU YOURSELF can perform a simple test to see if its BAD if you have an ohm meter, HOWEVER that wont tell you if its really GOOD............
An ohm meter across its small + and - terminals should read in the vicinity of 1.25 to under 2 ohms BUT IF ITS AN OPEN CIRCUIT THE COIL IS BADDDDDDDDDDDDDDDDD
An ohm meter placed between the HV output terminal and one of the small terminals should read in the neighborhood of say 5000 to 10000 ohms depending on the coil, BUT IF ITS AN OPEN CIRCUIT ITS BADDDDDDDDDDDD..
HOWEVER even if it passes BOTH tests above (primary and secondary winding contuniuty) it can still fail under HV and/or high temp conditions which it often does cuz HV breakdown happens i.e. a spark will jump where its NOT supposed to due to insulation failure.
You can also run a bench test by applying but then opening a connection of 6 volts across its small + and - terminals and each time the circuit is broken a HV spark should jump from a coil wire attached to its HV terminal to a battery post. You can do the same type coil test on the tractor
Heres my Ignition Troubleshooting Procedure
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=5745
John T
