Re: who can check a 6 v coil ?
Posted by couv on October 01, 2009 at 05:34:19 from (24.32.176.78):
In Reply to: who can check a 6 v coil ? posted by couv on September 30, 2009 at 19:31:23:
I got the dist to rotate, checked #1 TDC with the stiff wire, and rotor was pointing between #1 and 3 in cap. I rotated the dist until points sparked. Locked the dist down.
I am hand cranking it till I get the starter back from the shop. The bendix has a booger in it and it hangs up.
Tried the short shot of ether in the cleaner. Tried the main carb mixture screw at 1 turn out, and at 2 1/4 turns out.
Did I miss any of the suggestions ?
