Re: Roll Pin in Throttle Lever Backing Plate? IH 656, etc
Posted by IAGary on October 01, 2009 at 05:36:57 from (216.51.225.11):
In Reply to: Roll Pin in Throttle Lever Backing Plate? IH 656, etc posted by R. Smith on October 01, 2009 at 02:27:56:
With a diesel motor you turn off the engine by shuttin off the fuel.
That was a stop so you did not throttle down to far and turn off the fuel under normal operation.
When you wanted to shut off the fuel you lifted the throttle over the pin and it would then shut off.
I assume this is the pin you are referring to.
Gary
