350 alternator wiring.
Posted by Bob O2 Martin on October 01, 2009 at 13:47:49 from (71.7.67.73):
Not restoring this thing, just trying to get it to charge.
Question is; does the alternator circuit have to go through the ignition switch (two pole + start) or can I run the battery charging wire from the back of the alternator to the alternator side of the amp gauge without a switch in it?
This would leave this wire hot all the time, but I was thinking it was the way they worked and wouldn't drain the battery. Yay or nay?
Appreciate the help,
Bob
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
