Posted by D Slater on October 01, 2009 at 17:19:01 from (72.65.129.239):
In Reply to: m vs 400 posted by dmiowa on October 01, 2009 at 11:26:07:
In the past I used a SM with live hydraulic and a 3 point hitch with 2 cylinders to move some bales. PSI was set to max out near 1000 PSI. Worked okay but light on the front. Even with front wheel weights and frame weights upgrades could be a challengage unless backing even with the weights. This year I moved some with a 400D and late type 2 point with adapters to the 3 point bale carrier. I wondered if the 2 point with one cylinder would lift the bales. It did okay and that diesel engine maybe combined with a little longer wheel base kept the front on the ground just slightly better than the SM did without weights on the 400 front. Depending on bale size a 400 gas may get light on the front. If your already moving them on the back of a M without weights the 400 should do better if the hydraulic system is putting out what it should.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
