Posted by RustyFarmall on October 02, 2009 at 06:00:15 from (209.152.78.140):
In Reply to: fuel leak on M posted by nydolphin on October 02, 2009 at 05:19:48:
Is the needle valve SEAT screwed down tight and is the gasket good? Is the float in good condition? Is it set to the proper height and is it free to move up and down? Carburetors are much more complex than most people realize, and proper adjustments are NOT a guessing game.
Also, obviously the sediment bowl fuel shut-off is not working. A complete, new sediment bowl assembly is not that costly, and is the easiest, quickest way to solve that problem.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
