Posted by rustred on October 02, 2009 at 07:03:18 from (209.115.232.65):
In Reply to: fuel leak on M posted by nydolphin on October 02, 2009 at 05:19:48:
most probable cause would be needle&seat. it is located at the carb inlet behind the brass screen. BUT you need to remove carb and separate halves and remove float, by pulling out pin. then you can remove needle & look at it. the metal ones usually show the wear where its seating. the seat unscrews. best to just o/h the carb, as you will need to soak it in carb cleaner to dissolve junk out of it.after soaking wash in warm water and blow out all passages with air.rest later.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
