Re: fuel leak on M
Posted by D Slater on October 02, 2009 at 07:27:15 from (72.65.129.239):
In Reply to: fuel leak on M posted by nydolphin on October 02, 2009 at 05:19:48:
One way to check for a crack in lower casting is to put a fitting in the drain hole and a clear hose running up beside the bowl and higher.
Then you can see if the fuel level comes up higher or lower than the overflow. If it stays lower than the overflow and still leaks there's a leak in the bowl somewhere. You probably just need the carb gone through the.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
