Re: Torque Amplifier repair
Posted by mkirsch on October 02, 2009 at 09:56:12 from (64.80.108.57):
In Reply to: Torque Amplifier repair posted by jdbrad1 on October 02, 2009 at 08:50:05:
On the Farmalls, you need to do what is called a "double split" to get the TA unit out of the tractor. First split is at the engine/bell housing seam. Second split is behind the TA section.
Once that center section is out you can remove the TA and repair or replace it. On yours, I believe the part called the "ramp and rollers" is shot.
You need splitting stands to hold the tractor up and a cherry picker to lift the TA section out.
