I had a petronix elec ignition go bad after 2 yrs. Just before that it ran rough and I finally discovered sparks jumping all over around the sp wires when viewed at night. I had the high voltage coil also. Ordered some high voltage wires from Brillman Co (online) which fixed the sparking and rough running problems. The insulation on these plug wires is much better. Don't know if the sparking contributed to the elec ignition failure. I may have installed it a little cocked.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
