Re: fuel leak on M
Posted by GordoSD on October 02, 2009 at 12:51:58 from (216.106.254.217):
In Reply to: fuel leak on M posted by nydolphin on October 02, 2009 at 05:19:48:
I'd disconnect the fuel line from the carb, and then try opening and closing the sediment bowl valve. It could be your sediment bowl is OK. SHut the valve and see how long fuel drips out the opened fuel line.
Gordo
