Re: Touch Control Empty, Crankcase Too Full....
Posted by El Toro on October 02, 2009 at 17:28:51 from (74.103.74.58):
In Reply to: Touch Control Empty, Crankcase Too Full.... posted by Joshua Blauvelt on October 02, 2009 at 07:32:04:
third party image
Hi Josh, I haven't heard from you lately. If its your Super C it probably the hydraulic pump.
As Jim suggested the old seal has probably worn a groove causing the leakage into the engine.
Here's a breakdown on a Pesco pump Thompson is similar. Hal
PS: I guess it wont be long you will have the snow mobile running.
