An added thought . . .
Posted by ScottyHOMEy on October 02, 2009 at 18:56:46 from (64.222.246.201):
In Reply to: Re: oil filter case retaining bolt Gasket posted by ScottyHOMEy on October 02, 2009 at 09:26:26:
if you're going to be shopping around at other than a CaseIH dealer.
That 11/16" inside diameter is commonly referred to in a "nominal" size as a 5/8" washer, i.e., it's made to fit around a 5/8" bolt. Trick is that it's quite narrow, about 3/32", much more so than a common washer.
It's fading some, but the more common application for that type of washer is on automotive motor oil drain plugs. Second trick is that a lot of those anymore, where they still use them, are metric.
The thought is that you may be able to find one locally for that application. If you have the center bolt out anyway, take it with you and try a 5/8"/16mm drain plug gasket for fit. It might just do the trick.
