Zane: 3 point or fast hitch both require a remote hydraulic valve added to the touch control unit. If you buy a fast hitch, make sure you get the remote valve and check valve that goes with the hitch.
If you buy or build a hitch, your single biggest cost will be the hydraulic remote valve. You can operate a 3 point hitch, without remote valve, using pull rods from front rockshaft, however you will not be happy with the performance. It won't lift much.
I said buy Saginaw, all others are junk. your better off if you don't know them.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
