Re: 1486 needs more power
Posted by The tractor vet on October 02, 2009 at 20:19:12 from (75.19.126.160):
In Reply to: Re: 1486 needs more power posted by IAGary on October 02, 2009 at 20:11:29:
I would say that at 10% she should come to life IF the pmp shop was worth there salt . And at 10% she should be making some smoke . IF the pump shop set it to a 14 spec's . So i would check flow out of the tank and i would ALSO replace the line from the filter to the pump with the correct line and not some home made hose that i have seen on some as that hose has to PULSE and hyd. line does not work and a good way to flat up and TRASH a pump . And three turns on that pump she would be a fire breather
IF he is twisten the wright screw
