Re: Farmall 140 charging issue
Posted by Jeff 140 on October 03, 2009 at 10:51:27 from (71.58.184.152):
In Reply to: Re: Farmall 140 charging issue posted by Jeff 140 on October 03, 2009 at 06:47:29:
Put a new battery in the 140 - checked voltage again - battery reads 6.36V with cables on - reads 6.2V when I pull the ingnition switch (4 amps) - reads 6.36V running - ground the genny "F" terminal and the reading between "F" and "A" is 9.25V (5amp) and the reading between battery posts is 8.68V - if I measure between the "F" & "A" while running without the "F" grounded, I get a reading of .38V - still leaning toward a bad "new" VR
