dpski: Just to add to what Andrew and Scotty have said, and I agree with all they said. Block part number on these tractors is partially hidden behind the oil filter, and C is 251069 R1, SC is 354898 R1, 200 is 354898 R2 and 230 is 366204 R1.
C will have 3, 4 or 5 digit serial starting at 501, SC are all 6 digit serial starting at 100001, 200 start at 501 and go to aprox. 15000, 230 will start at 501 and go to about 8000. C tractor serial numbers will be close to engine serial numbers, SC will have larger engine serial numbers than tractor serial numbers. They start off same but increases gradually to 9000 difference by 1954.
Farmalls 100, 200, 130 and 230 tractor serial numbers each start at 501. The four engines have a common sequence of serial numbers, thus increase much faster than tractor serial numbers. Engine serial numbers on those 4 tractors get up to 58560 and there were 50649 total tractors. I presume the extra engines went as stationary engines, baler engines, etc. Same with SC.
There have I confused you enough? Come back if you have questions.
Then you go to casting date codes, C will be one of Q, R, S, T, U. SC will be one of W, X, Y and few Z. 200 will be one of Z, A or B. 230 will be one of B, C or D. Where you get overlap high serial will be older tractor, low serial number will be newer tractor.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
