Re: pre oiling new engine overhaul
Posted by BigC on October 03, 2009 at 16:10:39 from (74.215.94.63):
In Reply to: pre oiling new engine overhaul posted by Icuby on October 03, 2009 at 15:58:54:
You could use a preoiler but it might be overkill. As long as you used assembly lube you'll be fine. You ca always crank it over with out the spark plugs (gas) or injectors (diesel)
