Re: Sleeve retainer
Posted by John G. Hasler on October 03, 2009 at 16:26:31 from (174.124.28.201):
In Reply to: Sleeve retainer posted by Butch -Ia on October 03, 2009 at 15:20:31:
I used aluminum foil successfully to fix a loose sleeve on an 8N. I calculated the amount of foil needed to produce an interference fit, ran the sleeve well up above the block, sealed the top of the piston with grease, wrapped the foil on, filled the sleeve with LN2, waited for the sleeve to cool down and shrink, and ran the sleeve back down into the block. Held for several years until I rebuilt the engine.
