Re: New Farmall 450
Posted by CNKS on October 03, 2009 at 19:38:45 from (216.144.104.128):
In Reply to: New Farmall 450 posted by SCpuller1 on October 03, 2009 at 19:21:35:
Hytran in all but the engine. I think your tractor has a "seasonal disconnect" underneath. Try disconnecting it and see if the sound stops. You have a planetary PTO that turns all the time, unless the disconnect is used. When in use, the rear band keeps the shaft from turning, but the rest still rotates. Be sure the lever is locked in the forward position when off or it will slip. The front band engages the planetaries. Some will disagree, but you can run the TA in either position. Engage or disengage rapidly to prevent slippage. But for light duty you will probably use the TA in direct most of the time.
